vcFrameSet
vcFrameSet is a type of geometry set that contains a collection of frames.
Module: vcGeometry
Parent: vcGeometrySet
FrameCountIntegerRGets the number of frames in set.
createFrameNonevcMatrix matrixCreates a new frame in set.
matrix (vcMatrix): Frame transformation.
deleteFrameNoneInteger indexDeletes a frame at a given index from set.
index (int): The index of the frame.
IndexError: When the index is out of range.
getFramevcMatrixInteger indexGets the position matrix of a frame at a given index in set.
setFrameNoneInteger index,
vcMatrix matrix
Sets the position matrix of a frame at a given index in set.
updateNoneNoneUpdates all frames in set, thereby updating the set's bounding box.
